Interesting debate going on down there. Both sides are right, the only question that remains is....what is RIGHT for you? I've always tried to err on the safe side and go with new sleeves and pistons. That being said, as I get older and look back, it looks to me like I've wasted some money. If the tractor didnt smoke or use oil and if the cylinders are not scored up, drop a bearing or 2 and take a look. If bearings are not scuffed and worn, rings should still be decent as well. At that point, you have simply done a valve job and took a look at the lower end and tightened up some leaks. You do run a slight risk of the tractor sucking oil past the rings, but even if it does use a little oil, as long as it doesnt smoke, you can afford to buy a little oil. That being said, if you even suspect you may end up asking the tractor to work for a living, then there would be no question in my mind but to go with sleeves and pistons, rods and mains. The comment below about micrometers and guages is spot on. Lots of good parts that are within working specs get thrown away every day. Unfortunately, I have been guilty of that as well.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
