Re: Farmall 140 PTO question
Posted by banjo on January 02, 2008 at 22:10:50 from (65.67.203.113):
In Reply to: Farmall 140 PTO question posted by Bruce Covey on January 02, 2008 at 17:55:18:
One problem you may have is no independent pto for tiller use. if the ground is hard you might have a tough time with the speed of the tractor.Also if you modify the 3 point to get the driveshaft inline ,will you be able to till your tracks out.
