hydro fliud leaking on 450
Posted by Bill thompson on January 07, 2008 at 17:13:47 from (204.13.113.102):
Before I changed out the 13 gal. of hydro fluid, I fixed all the leaks. It was 73 degrees in St. Loius the last two days so I power washed the 50 years of ??????????? off the tractor. Pulled it back in the barn and a hydro leak appeared. There are two plates on the bottom 2x6 and a 2x6 t plate. In front of the T plate are two holes (look like threaded holes which fluid came out.) Is that right? there are no other leaks.
