Re: Farmall H ignition
Posted by dan harjes on January 09, 2008 at 21:06:45 from (75.161.129.45):
In Reply to: Re: Farmall H ignition posted by El Toro on January 09, 2008 at 15:33:41:
Wow...do I see an issue now after seeing the drawing...Why I did it...who knows...ok, on the alternator...the #1 drops down to the coil and the #2 goes back to the battery...just like you said...re--charges the battery. My splice runs the #1 into the #2 line...just father down the line where the 10Ga. wire is...thus sending a charge from the alternater into the coil...at least I think that was what will happen...ooops
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
