Posted by El Toro on January 09, 2008 at 15:33:41 from (64.12.116.73):
In Reply to: Re: Farmall H ignition posted by dan harjes on January 09, 2008 at 13:28:35:
Your alternator has nothing to with the ignition. It's purpose is to keep the battery charged. You should post a picture on how you have the tractor's ignition wired.
You need to use a test lite or volt meter to see if there's battery voltage at the ignition switch and at your coil. You can tell if the ignition is ok by pulling off a plug wire and hold it near the plug while someone makes an attempt to start your tractor. If you have fire from the plug wire you probably have fuel problems. Hal Post a picture of that alternator splice.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
