Re: no luck with farmall H ignition
Posted by Nebraska Cowman on January 12, 2008 at 10:23:54 from (65.162.146.181):
In Reply to: no luck with farmall H ignition posted by dan harjes on January 12, 2008 at 10:09:31:
Yeah, loose post on the starter is a big No No. You will have to get that fixed. The good news is if you have help you can tow the tractor to start it. On an H you don't need much speed. Use 4th gear unless the wheels want to slide, then use 5th.
