no luck with farmall H ignition
Posted by dan harjes on January 12, 2008 at 10:09:31 from (71.220.115.187):
Few days ago, got lots of help on ignition problems. I used the 12v conversion chart and fired right up. Would'nt turn off! Seems I put the coil and alternater #1 field wires on same side of the push/pull switch, oops. I corrected that and then hit starter. I got just a bit more than a "click". It turned the a fraction and then nothing. Cleaned every post from battery to the starter motor. I did note that the post on the starter does want to spin on the housing.
Did I just loose my starter? How would I test only the starter? jump from truck to starter motor and it should spin?
As for the not turning off, was that only because I hade the wires to the +coil and #1 field on alternator to the same side pole on push/pull ignition switch?
Man, Frustrated. Comments? Thanks, Dan
