Re: no luck with farmall H ignition
Posted by Janicholson on January 12, 2008 at 11:31:11 from (66.173.50.180):
In Reply to: no luck with farmall H ignition posted by dan harjes on January 12, 2008 at 10:09:31:
third party image
Here is a diagram of the ignition system parts.
The starter is only likely to be stuck. Unstick as described in the other posts. If the lights do not dim when the starter rod/lever is actuated, the starter lead described as loose may be broken. Good luck, and let us know the outcomes. JimN
