Re: What makes a TA slip?
Posted by Kevin Meier on January 18, 2008 at 20:02:25 from (64.71.85.247):
In Reply to: What makes a TA slip? posted by charles todd on January 18, 2008 at 19:30:08:
A mechanical ta will slip on the high side if it is adjusted wrong, ta clutch and flywheel are bad or your primary clutch is bad. I can believe you knurled your rollers and that works. A roller should hardness test around 58 hrc which is pretty much impossible to knurl. I have almost any of the parts you may need or a replacement t/a email me if interested, or need any help. I"ve been building ta"s for 15 years now. Good luck
Kevin
