Re: Rear hub extensions for Farmall Cub
Posted by Gene on January 23, 2008 at 15:51:46 from (64.85.220.164):
In Reply to: Rear hub extensions for Farmall Cub posted by migraine on January 23, 2008 at 09:41:38:
If they are IH part #: 355 066 R1 they are worth a number of dollars. There are also recent after market extensions available.
You can also put a set of duals on your Cub with a set.
