Re: Rear hub extensions for Farmall Cub
Posted by migraine on January 24, 2008 at 08:35:42 from (67.182.151.248):
In Reply to: Re: Rear hub extensions for Farmall Cub posted by Gene on January 23, 2008 at 15:51:46:
Thanks, I went and cleaned up the hub extensions this a.m and they are the numbers you listed. They are 6 inch not 8 as I said yesterday. Guess I'll decide what to do with them, maybe put duals on a Cub? Migraine
