Re: valve job or more on A ?
Posted by Janicholson on January 25, 2008 at 06:24:32 from (199.17.6.122):
In Reply to: valve job or more on A ? posted by chuck davis on January 25, 2008 at 05:16:40:
Most As were dual fuel (with a gasoline starting tank, little cap, and a distillate main tank) The compression on one of these is at te 90 pound area. If it is only giving a puff at startup, and runs well without fouling plugs, I would not tear into it at all. If it smokes at idle, and when ideling down from going fast in road gear, I would consider valve guide seals applied without removing the head. JimN
