Re: BD-154 - Diesel what a mess, Advice please
Posted by MN Scott on January 26, 2008 at 06:30:11 from (206.9.216.62):
In Reply to: BD-154 - Diesel what a mess, Advice please posted by Ed8844 on January 25, 2008 at 22:44:40:
I would replace the pistons/sleeve assemblies.. You can most likely get a kit with the sleeves, pistons, rings, bearings and gaskets for a decent price. Your better off to put in new sleeves to match the new pistons as just buying the pistons alone will cost as much or more than an an entire rebuild kit. If you can get a head complete and ready to bolt on for $500 that sounds reasonable. Diesel heads are spendy.
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
