BD-154 - Diesel what a mess, Advice please
Posted by Ed8844 on January 25, 2008 at 22:44:40 from (74.229.216.165):
I've been at this thing for a while now,
Trying to get my 3444 in shape - Had no compression in #4 cylinder Pulled the head and sleeves look good
Head had some problems Pre combustion chamber on #4 and #2 were loose and made contact with pistons causing a wear spot in tops of both.Engine never locked up or jamed Cylinder head shop says the head has a crack in the # 4 and #2 PC chambers and is history - (get another one they say)
Here comes the question - when I replace the head Im worried that the pistons will break at the wear spots One is 1/8" deep and in the shape of the chamber face and the other is 1/32" deep same shape- I dont know how thick Piston faces are -Are they tuff enough to leave in place if no cracks are visible ? Should I replace them ? Can I replace just the real bad one in-frame or must all 4 be done together,
Thanks for the help.
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
