J, the cracks are near or part of older pin repairs. Its leaking around the pins too - The picture shows the older pin repair right on the thin bridge between the exhaust valve seat and the precombustion chamber - The crack is hard to see but extends down into the valve chamber - The other problem looks identical but without the crack in the lower valve chamber - Both could probably be repaired with a bigger pin or furnace welding. I dont know if it would be worth doing or if it would hold up- We only have a couple shops in Jax for head work Ill call around Monday for the other one. The 2nd picture is the top of my Piston after the insert in the Head came loose There are two like this - ok275 at bellsouth dot net
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
