Re: Difference between an A and Super A?
Posted by CNKS on January 26, 2008 at 19:22:01 from (216.144.104.128):
In Reply to: Re: Difference between an A and Super A? posted by Hugh MacKay on January 26, 2008 at 18:36:51:
I have never seen a Super A1, if I do I will buy it, provided it doesn't cost an arm or leg. Again I rely on Guy Fay's info, although he makes mistakes like every one else, such as, he says the SN is on the seat bracket--if you have seen one I will take your word for it. Guy does say that the 100 had it on the bell housing. As you say the 100 and SA1 are (mostly?) the same except for the sheet metal. It does seem that since the SA1 was a "running" change (without the hoopla the introduction of the hundred series brought) with the C123 engine and taller radiator, that IH would have left the tag alone. But, what makes sense to me seldom works out that way.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
