Re: M MAIN BEARINGS
Posted by Janicholson on January 31, 2008 at 11:08:04 from (199.17.6.122):
In Reply to: Re: M MAIN BEARINGS posted by Buck E on January 31, 2008 at 10:59:40:
The problem with a mic is that the crank must be out of the block. If it was running well, has oil pressure, and no knock, putting bearings back in it that match the inserts removed will work fine. The shell should be marked with Std (standard), or .002 etc. undresize. JimN
