Re: SECTOR GEAR DISASSEMBLY
Posted by gene bender on February 05, 2008 at 15:51:27 from (67.55.226.214):
In Reply to: SECTOR GEAR DISASSEMBLY posted by chuck davis on February 05, 2008 at 10:58:10:
All parts are avail from dealer. Is the bearing in good shape it not needs to be changed of the several i have repaired in the last few yrs only one needed the new top bearing. It should come offmaybe need a puller. I would replace the key and all the bushings. Now the bearing on the end of steering shaft i would make sure it was a new one it doesent take much play in that one for steering wheel play So two bushings,two bearings,two seals and key and gasket your steering will be like new again. If the ball ends on draglinks are egg shaped a little work with calipers and 4in disc sander will make them round again.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
