Re: SECTOR GEAR DISASSEMBLY
Posted by chuck davis on February 06, 2008 at 04:56:54 from (216.176.157.202):
In Reply to: SECTOR GEAR DISASSEMBLY posted by chuck davis on February 05, 2008 at 10:58:10:
Thanks Gene, The top bearing is the worse of the two.The sector has zero slop on the shaft,i was quite suprised by that after reading through the archives.
I think most of my problem is in the steering gear arm. It is worn badly,so much so that it was beyond tightening.
I think i am going to try to weld it up and use a die grinder to reshape it. I dont know if that will work.
From what i have read i dont know what other options i have, as it is the old style front with adjustable tie rods.
