Re: Switch
Posted by James Williams on February 09, 2008 at 05:54:39 from (170.215.129.166):
In Reply to: Switch posted by Tom Windsor on February 08, 2008 at 19:27:47:
Tom,Im not a expert but that switch is for a generator with a cutout,First stop low charge,2nd stop before the light circuit is high charge this way the gen.will keep up with the amps that the lights pull.While using your tractor during daylight hours low charge was only needed.If you turned the lights on without being in high charge side your battery would be drained.The way the switch is wired you had to be on the high charge when you turned your lights on.
jimmy
