Posted by RustyFarmall on February 09, 2008 at 06:10:15 from (209.152.78.71):
In Reply to: Re: Switch posted by James Williams on February 09, 2008 at 05:54:39:
No, that is wrong. If you are using a generator cut-out, you need the 4 position switch. Low charge, high charge, dim lights, and bright lights. The 3 position switch is for a voltage regulator set-up. Off, dim lights, and bright lights.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
