Posted by CNKS on February 09, 2008 at 18:45:11 from (216.144.104.128):
In Reply to: Re: My W6 Won't Run posted by TONYR on February 09, 2008 at 16:10:30:
You are SURE that the carb to gov connection is correct? That connection is not easy to make, and it is easy to get it out of line even if you think it is correct until it goes out of sight. Your symptoms match that. Usually, in that situation, they don't rev up when going off choke, they sputter and die. The type of carb doesn't make a lot of difference. Externally the kerosene/distillate has a drain cock, gasoline a plug. You could have the carb out of adjustment. Use an intial setting of 1 turn out for the idle and three turns out for the main jet.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
