Re: 656 Gas/ 263/1966
Posted by GD720D on February 10, 2008 at 11:09:35 from (66.226.101.168):
In Reply to: 656 Gas/ 263/1966 posted by Jerry Gilliam on February 10, 2008 at 10:07:23:
That carpment should be dry. Oil is leaking from around the pto drive shaft. Could also be leaking from the Ta. sun gear shaft or the T.A. Carrier. Would need to split ther tractor if any of the seals leak. If not leaking bad clean the hole out and let it drip
