Posted by Jerry Gilliam on February 10, 2008 at 10:07:23 from (66.21.222.199):
I know I'm tiring the board and sure wish i could talk to the Tractor Vet(As he seems to know a lot about he 56 models). But I'm sure others have had similar experiences.
It seems that I was hood winked on this buy. After having the tractor for about 2 weeks and driving her some, the oil started dripping out the weep hole under the center compartment and near the hyd filter. Question: If you pull the first cover "underneath" coming from the rear housing(sets almost under the TA and is approx 12 " long, wider on end toward rear than toward front of tractor) should oil be in that area? There is so much oil around, i don't know what covers are supposed to contain oil and what doesn't. There are two inspection covers underneath the TA on the bottom of the center housing. Thanks Jerry
PS The I&T manuel is more concerned about Hyd drive that explaining some simple features. Can't find a thing on internal seal replacement on PTO shaft or TA shaft.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
