Re: Where to brace this Farmall 504 axle (pictures)
Posted by Brownie450 on February 11, 2008 at 03:23:40 from (216.51.158.220):
In Reply to: Where to brace this Farmall 504 axle (pictures) posted by Charles Todd on February 10, 2008 at 18:48:07:
You could improve this unit by using 4 inch channel to go across the wishbone & then drop 2 channels from the elongiated bolt holes in the main frame. Weld & gusset all corners. Still might not be enough for a loader. Flotation tires pick up every bump that is in the way when not carrying a load & have twice the ground contact area as opposed to a 3 rib front. If a loader is rated for picking up 1200 lbs. someone will need to lift 1201 lbs or MORE.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
