Posted by Charles Todd on February 12, 2008 at 10:00:17 from (205.242.95.139):
(From Hugh McKay)
Charles: How much do you know about the history of this tractor? Do you have any photos of futher back on chassis? You asked the question, could a 282 fit in between rad and clutch housing. I don't think, 504 all had a long fan shaft anyhow, but I don't think it's long enough for 2 more cylinders.
I had a 504, however I didn't keep it very long, thus I don't remember a lot of detail. My 504 and 656 came with farmland I bought, the owner had bought both tractors new in 67, along with a 2000 loader on the 656. He had changed the loader from 656 to the 504 and had to cut 6" out of loader frame back near rear axle housings. (actually saved the pieces) Since I wasn't going to keep the 504, but wanted to keep the loader, I had to weld those 6" frame pieces back to install the loader on my 560, that's right 560 and 656 have the same length chassis and wheel base.
The reason I raise this, keeping in mind I just don't remember about 504, something doesn't look quite normal with your tractor. That is the reason I asked about more photos. Have you got a 504 that someone rebuilt using some 560 and 656 parts, exculding the wide front? How long is the tractors wheel base? In that era, most 4 cylinder Farmalls were close to 90" wheelbase and small chassis 6 cylinder tractors like 560 and 656 were close to 96" wheel base. Just the 6" from my loader frame difference. Those figures could vary a bit narrow front is not exactly same as wide front, and the after market front end you have may be a bit different also, however they should fall between 88" and 93" for 4 cylinder and 94" to 98" for 6 cylinder.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
