The electronics in the "new" distributor will just take the place of the points. This means that it is wired normally, as John T point out. The interesting thing to me (and maybe it makes it easier in my head also) is that electrons flow from negative to positive, thus the effort in a positive ground system is to hurd them back to ground. The original push pull mushroom switch will need to be replaced. It is a grounding switch and cannot have any hot (negative) wires attached as it will be a short to ground. New (stock, or stock looking) distributor switches are pricy, but available. If you are not looking to make a trailer queen, a high quality warer resistant single pole single throw keyed switch can be used to supply ignition volts. It should be atteched on the supply side to the load side of the amp meter. A five amp inline fuse in that wire is also nice. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
