Re: Super A - convert magneto to coil
Posted by Michael C in TN on February 13, 2008 at 08:09:00 from (68.119.111.80):
In Reply to: Re: Super A - convert magneto to coil posted by John T on February 13, 2008 at 06:57:55:
John T, it sure does get confusing for me.
"(if Pos ground + wires to dist if Neg ground - wires to distributor)".
Assuming a 6v + ground (current) the hot wire going to the coil would read -6v on a digital meter?. And go to the NEGATIVE terminal???. At close to $100 for the e module you sure don,t to melt it.it
As for the switch I reckon you are saying it,s a ground interrupt and not a voltage capable switch?
It.s a whole lot easier to envision how to wire the 12v - ground wiring.
