Mike - I'm with you! Recommend setting up the tractor up for 12 volt NEGATIVE ground. Then replace the magneto with an IHC distributor and coil. Finally install a 12 volt negative ground electronic ignition kit in the distributor.
When you are done your Super A will be set up like virtually every modern automobile and truck. This drastically reduces the chances for a jumper cable polarity error (which can fry the electronic ignition...) should your tractor ever need to be jump started.
Check your local tractor boneyard for a distributor/coil assembly - or check on Ebay.
And if your magneto is still "hot" you can probably sell it for more than what you'll pay for a used distributor, thus dramatically reducing your finished cost.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
