Re: IHC 1468 V8
Posted by Dan Henebry on February 13, 2008 at 15:32:40 from (12.147.63.126):
In Reply to: Re: IHC 1468 V8 posted by N.D. FArmall H puller on February 13, 2008 at 14:17:33:
My father use to work for IH then and i don't think they had too many problems with the motor other than you get more torque from a staigth six. The biggest problem I believe was that there was tooooo much room to turn these motors up and guys were tearing out the rearends of these tractors.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
