Re: IHC 1468 V8
Posted by w.g. on February 13, 2008 at 16:10:58 from (64.12.116.73):
In Reply to: Re: IHC 1468 V8 posted by Dan Henebry on February 13, 2008 at 15:32:40:
they still use the isx cummins enging in the tj and stiger 535, and the cummins in the stiger and tj 330. everything else is iveco
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
