Coil
Posted by Bob on February 15, 2008 at 20:16:38 from (69.178.229.154):
In Reply to: Re: fireworks ! posted by tooltime on February 15, 2008 at 19:24:33:
If your setup has a "starting bypass", keep a 6-Volt coil and use a resistor.
If NO starting bypass (most likely), get a TRUE 12-Volt coil, such as the NAPA 14SB.
Incidently, there is NO "built-in resistor" in the TRUE 12-Volt coils, just MORE turns of wire in the primary winding.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
