Re: fireworks !
Posted by tooltime on February 15, 2008 at 19:24:33 from (66.103.167.60):
In Reply to: fireworks ! posted by tooltime on February 15, 2008 at 17:42:25:
i found a small crack on the coil, the ridge that runs around where you connect coil wire. i bought all new wires, ( TSC COPPER CORE- 7MM ) came as a kit. should i replace with new wires, and coil?? could i get a 12 volt coil with buil in resistor, and bypass ballast resistor or shoul i just get a replacement 6 volt coil, thanks guys. Jim
  • Coil Bob 20:16:38 02/15/08 (2)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
