Re: 806 Uh oh, oil is overfilling itself
Posted by K.B.-826 on February 20, 2008 at 17:41:58 from (24.180.151.198):
In Reply to: 806 Uh oh, oil is overfilling itself posted by mhalter on February 20, 2008 at 17:11:35:
There is no possible way for hy-tran to be mixing with engine oil on an 806. You need new seals on your injection pump driveshaft.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
