Re: New Clutch / same old problem
Posted by glennster on February 22, 2008 at 13:41:50 from (75.57.135.167):
In Reply to: New Clutch / same old problem posted by wood-haulin-cubber on February 22, 2008 at 13:28:48:
with the tractor in gear does the clutch disengage ok ? what oil are you running in the rear end? if the clutch isnt hanging up anywhere, no burrs on shaft ect, maybe try some 140 wt in the rear end. too light of oil will let the shaft coast and not come to a stop causing the grinding.
