Posted by wood-haulin-cubber on February 22, 2008 at 13:28:48 from (74.69.228.139):
Just installed a new clutch in our 51' Cub. New disc/ new pressure plate/ new throw-out-bearing...all brand new...all went good, no problems (this time). Just took the tractor for a ride & it's got the same symptoms as old clutch...when 1st shifting into any gear, I step on the clutch, idle down & go to shift...the problem is that the shaft must still be spinning in the tranny because it causes a grinding sound...it sounds like I'm going to chip gears? Any ideas? We've had this tractor for years & just developed these symptoms over past year or so....I thought for sure the new clutch would solve it...I double checked the pressureplate before installing & I tried adjusting the clutch pedal, it seems as though no matter how far I depress the clutch , it doesn't stop the input shaft from spinning? Thanks for ideas.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
