Re: New Clutch / same old problem
Posted by wood-haulin-cubber on February 22, 2008 at 14:29:34 from (74.69.228.139):
In Reply to: Re: New Clutch / same old problem posted by old on February 22, 2008 at 14:14:52:
what is a pilot bearing? is it behind the flyweel, pressed into the crankshaft?
