Re: New Clutch / same old problem
Posted by old on February 22, 2008 at 14:14:52 from (4.245.1.86):
In Reply to: Re: New Clutch / same old problem posted by wood-haulin-cubber on February 22, 2008 at 13:44:50:
Sounds about right and also the right fluid. Another thing it could be is a bad pilot bearing if you didn't replace it that could be the problem also
