On many 4 terminal Voltge Regulators (BAT FLD LOAD GEN) the Gen/Arm terminal is off on one side by itself or the bottom often unlabeled. On 3 terminal VR's the BAT ARM/GEN FLD are all side by side.
Its possible to use EITHER a 3 or 4 terminal VR n they both can work if wired correct.
BAT to load (not battery/starter) side of ammeter
ARM/GEN to geyys ARM post
FLD to gennys FLD post
LOAD feeds hot battery voltage up to the lights n ignition via a wire to their switches BAT input terminals
On a 3 terminal VR with no LOAD terminal, lights n ignition are fed off the ammeters Load terminal, same one that wires down to BAT on the VR. If you didnt use the 4 terminal L terminal the lights n ignition will still work if fed instead from the ammeters Load terminal, but if I had a 4 terminal VR and the tractor previously used a 3 terminal or cutout before, I would remove the lights n ignition voltage feed wires from the ammeter n instead wire feed them off the LOAD terminal on a 4 terminal VR
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
