Re: New Clutch / same old problem
Posted by jim ll on February 23, 2008 at 04:10:13 from (205.188.116.73):
In Reply to: New Clutch / same old problem posted by wood-haulin-cubber on February 22, 2008 at 13:28:48:
the farmall cub is almost the only clutch that comes without the three fingers on the pressure plate pre adjusted. Once you install i ton the flywheel according to the manual your supposed to adjust the fingers to a certain height and they alll have to match. And from experience it DOES matter. If one is far out it won"t fully release that third of the clutch. And read the book close because if you are off the wrong way when you push the clutch down the throwout bearing hits the clutch and knocks. It is possibl eto adjust them thru the bottom hole although diffacult. Go to farmall cubs-com and put the question to them and you"ll get plenty of good answers jim
