Re: Farmall H Generator and Regulator
Posted by Gauger on February 23, 2008 at 06:24:14 from (4.252.159.181):
In Reply to: Farmall H Generator and Regulator posted by Andy Motteberg on February 22, 2008 at 13:48:24:
GEN is the bottom on 100% of the regulators I've seen. Polarize the generator before starting the engine by momentarily touching a jumper wire between "BAT" on the regulator and "A" on generator
