Cub Clutch
Posted by scott 1957lboy on February 25, 2008 at 20:34:23 from (68.238.25.246):
I have an older loboy (1957). It sat for awhile and runs real good. My problem is when I push in the clutch the engine slows down a bit. Also it tends to grind when I put it in gear. I have adjusted the pedal to the point the throwout yolk started to grind around the pressure plate and adjusted so it's just misses it. I still have a problem geting it into gear sometimes. I got under the tractor with it running and pushed the clutch in and saw the the driveshaft is turning very slow when the clutch is depressed. Is it time for a new disc? or could it frozen to the pressure plate? I really want to avoid spliting the tractor if there is an easier fix. Thanks for input. Scott
