Posted by Janicholson on February 26, 2008 at 05:54:57 from (199.17.6.122):
In Reply to: Cub Clutch posted by scott 1957lboy on February 25, 2008 at 20:34:23:
The pilot bearing in the center of the flywheel (that takes the very tip of the clutch shaft) could be needing lube, or bad. The splines on the clutch shaft could be worn, allowing it to hang up on the disk causing the disk to rub the PP. The last issue might be the disk being warped some causing it to drag on the FW, or PP, or both. Other than possible lube of the pilot, splitting may be needed. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
