Re: Still no spark on #3 cylinder?
Posted by JT on February 26, 2008 at 13:24:56 from (70.226.202.3):
In Reply to: Still no spark on #3 cylinder? posted by unioncreek on February 26, 2008 at 12:57:55:
Are you actually testing for spark with a tester, or are you assuming that it has not spark because of a dead cylinder? You obviously did put new plugs in? Did you get copper cored wires? If you have done all you said you done, there is really no way you could not have fire on #3. I would start lookign for mechanical problems. Stuck valve for one, blown manifld gasket, had that on an H once. Something just does not add up here.
Jim
