Update on #3 plug not firing.
Posted by unioncree on February 27, 2008 at 06:17:38 from (134.121.226.24):
Well the problems seems to self corrected itself. I took off work a little early to fix it, since this type of thing bugs me until it's fixed. It was raining slightly so I decided to put the tractor in the barn, it started right up and ran fine, #3 plug was firing.
I wish I had found the problem since it will be in the back of my mind that the problem could pop up when I'm haying.
Thanks for all the advise.
Bob
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
