Re: Update on #3 plug not firing.
Posted by Jerry Gilliam on February 27, 2008 at 07:26:01 from (74.250.1.24):
In Reply to: Update on #3 plug not firing. posted by unioncree on February 27, 2008 at 06:17:38:
The more easy way to check for a firing problem on a plug is to remove plug wire and attach another plug to wire. Ground plug to tractor and see if that plug is firing outside the cyl. If it is getting fire and you see a good blue/yellow streak popping inside the plug tip, then you will have fire delivery when you reattach to that plug screwed into the #3 head.
Jerry
