After you get done what Jim suggested, have someone (or do it yourself) fabricate brackets to fit the bolt holes up along side of the one you are working on. I repaired more than one of those. On some I tapped the casting out to 7/8. If the 3/4 holes aren't too bad I got studs from John Deere that had a larger than standard thread on one end and fitted them as deep as they would go. then use nuts to fasten the bracket on. Then fabricate the irons , weld them to the bottom bracket and bolt them to the sides. The ones I repaired never came loose again.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
