Re: TractorManNC (PICS) Farmall 504.........
Posted by TractormanNC on March 05, 2008 at 04:14:52 from (209.42.180.129):
In Reply to: Re: TractorManNC (PICS) Farmall 504......... posted by Charles Todd on March 04, 2008 at 17:48:49:
Charles,
Yes these ports are sometimes called O ring boss ports. In fact some IH tractors have standard SAE O ring fittings at the valves instead of the banjo fittings. Sounds like someone did a hack job that you are trying to clean up.
The compression fittings are NOT the brass ones that are used with copper tubing. The ones I am talking about are all steel. There are crimp on hose ends with a nut and compression sleeve to go on the tube. Weatherhead calls theirs "ERMETO".
