TractorMan, you are saying that the banjo fittings are standard SAE O-Ring ports... Is this a "Boss" fitting? If so, I have access to these.
Secondly, when you say a compression fitting, we are talking about the ferrule and nut job?
I personaly would like to remove the banjos and use 90 deg fittings to clean up the arrangement. There are stacked banjos on the rear of both valves that used to go to the single action ports on the front that were disconnected. Rather than use a shorter banjo bolt, they were crimped and brazed. The pressure generated when I tried to apply downforce blew a pin-hole in the braze.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
