Re: 450 won't run no compression
Posted by Janicholson on March 10, 2008 at 09:18:12 from (199.17.6.122):
In Reply to: 450 won't run no compression posted by HOSS357 on March 10, 2008 at 07:35:53:
Or the cam gear broke and the only two cylinders with closed valves are 1 and 4. Pull the valve cover and look at the valve train while cranking. If it moves, it is then necessary to check its timing against the engine's piston position. Good luck, JimN
